Why the national electrical code for dwelling units don't apply the continuous and non continuous load to calculate the over load protection device and cable selection calculation, correction factors for temperature
The national electrical code discuses about the motor-compressor, motor-compressor largest load, protective device, and no discussion about air handling units, chillers
the national electrical code discuses the method of calculating the demand load one panel board the question if I have panel (A) and (B), (C), (D), each of them contain lighting , motors and sockets loads and appliances and air conditions how I cane calculate the demand load for the main panel MDB-1 that feed all this panel boards and the main feeder, main circuit breaker and calculate the demand load of panel board MDB that feed the (MDB-1), (MDB-2), (MDB-3), (MDB-4) ,main feeder, main circuit breaker where (MDB-2), (MDB-3), (MDB-4) same as MDB-1 but different in loads not typical and, also calculation transformer load.
The national electrical code discuses the demand loads of central space heating only for optional method for dwelling units what about the general method for dwelling units and the non-dwelling units.
