I know the code says piping likely to be energized shall be bonded, and that can include natural gas pipe.
The code also says Natural gas piping shouldn't be used for a grounding electrode.
But if you connect the pipe to the panels ground bar to bond it, doesn't it automatically become a grounding electrode? What is the real difference between bonding it and using it as a ground? Is the only difference the wire size used to connect the gas pipe?
Steve
Steve
