dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
Some back round aerial service SE cable disconnect in the basement of house in main lug panel gas pipe and water often enter house in same area.
250.104B talks about bonding metal pipe likely to be energized.
I have seen GEC leave panel box and in one piece (no splices) connect to incoming water main then go around water meter connection clamp again, then final end connect to metal gas main. Is this a correct practice?
Where some of my confusion comes in I'm doing 2017 NEC MH videos and the way I'm hearing it is gas pipe will only become energized by a device like a furnace that has power connected to it (120v for fan blower). So that circuit is adequate bonding and the extension to the gas pipe is not necessary. In my area the pipe often runs thru much of basements in close proximity to wiring so would that be likely to become energized?
Also in my small mind i get concerned with bonding to gas and possibly creating an arc that causes a problem or ignites gas within pipe
Please help confused
