electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
This is how the repeaters in submarine fiber optic cables are powered (From wikipedia):
Repeaters are powered by a constant direct current passed down the conductor near the centre of the cable, so all repeaters in a cable are in series. Power feed equipment is installed at the terminal stations. Typically both ends share the current generation with one end providing a positive voltage and the other a negative voltage. A virtual earth point exists roughly half way along the cable under normal operation. The amplifiers or repeaters derive their power from the potential difference drop across them.
So if I understand this correctly, station A has a dc power source with the positive connected to the cable's power conductor, and the negative connected to a good earth ground. Station B has the negative connected to the cable's power conductor and the positive connected to earth ground. I wonder how much potential they typically use? Think they drive a ground rod in the middle of the atlantic at that neutral point
