NEC 110.26(C)(3)
wyboy
In regards to panic hardware required within 25 feet of work space of electrical equipment rated over 800 amps-NEC 110.26(C)(3): Do all egress doors within 25 feet of work space need to be equipped with panic hardware even if the door does not lead directly from an electrical room. Another words, if there is panic hardware on the door leading out of the electrical room into an office and the door leading from the office to the hall was less than 25 feet from the work space would it need panic hardware as well even though there is no electrical equipment in the office? The picture on page 39 of the Analysis of Changes to the 2014 NEC seems to imply this requirement.
Duplicate
NOTE: Posting the same question multiple times in multiple forums is not a good idea. As far as I can tell this is the third time this question has been asked. It has been responded to in the "duplicate" noted above. If the answers are unsatisfactory, ask for clarifications there.
