I was just going over some literature regarding Box Fill & noticed that conduit entering or a box connector used for connecting the conduit to the box is not used in the Box fill calc. If I remember years ago the code stated 1 conductor for clamps or connectors. I read 314.16(B) which states no allowance needed for small fittings such as lock nuts and bushings but, it seems to me that a box connector takes up just as much room if not more then a cable clamp but it's not counted? Is this correct?
