(b) Features and Location ? On-Site Standby Generator.
The disconnecting means for an on-site standby
generator(s) used as the alternate power source shall be
installed in accordance with 700.10(B)(5) for emergency
circuits and shall be lockable in the closed position.
Does this mean a disconnecting means for a fire pump can be located in the same enclosure or vertical switchboard section that supplies the emergency loads (700)?
Or Does it simply say it has to follow the requirement of 700.10(B)(5), which means the fire pump disc has to be totally separated from any other loads (700, 701, and 702)?
