chip8888
New member
- Ames, Iowa, United States
A customer has a house with a basement utility room (12 ft x 40 ft) that contains the main breaker panel with service disconnect, which is 3 feet away from a sink, 6 feet away from a toilet, 3 ft away from water treatment equipment and 6 ft away from furnace. House was built in 1982 (before rule disallowing panels in bathrooms).
The customer wants to add a wall with a door (and also considering a hidden bookshelf door) which would reduce the size of the enclosed utility room to 12x8 ft, effectively making it appear more as a bathroom. The resulting room would contain the same plumbing, hvac, and electrical components as before, however the customer also wants to replace the plumbing fixtures which will also require moving pipes.
Question is, is the current area considered to be a bathroom, and/or would adding a wall turn it into a bathroom or reset grandfathering? I’m unclear on what “area” means precisely for the definition of “bathroom” - does it mean enclosed by walls? Or any limiting dimensions or proximities?
If considered a bathroom, if the area around the panel were to be enclosed into a closet (with sufficient access area) separate from the plumbing fixtures, then would that suffice, even if the only means to access require going through the “bathroom”?
Another question is would using a hidden bookshelf door (as opposed to regular door) have implications?
Thanks for any help.
