NEC 2017 - Outlet along 24 ft sliding door
Piramyd
Hi there !
I am a little bit confused regarding the 12 ft requirement between outlets in residential. in the case of 24 ft sliding door.
This door has 6 panels with one fixed.. I know that a fixed panel is counted as a wall line.
So , should it be any outlet along the other 5 sliding panels.?
NEC 2017 article 210.52 (A) gets me confused in this respect..
I would appreciate any help.
Thank you in advance.
Hi there !
No, no receptacles required for the sliding panels. You just need enough receptacles so that no point along the wall line of the fixed panel is more than 6' from a receptacle.
With 6 panels and 24' total, each panel is about 4'. So if your fixed panel is at one end, you can rely on a receptacle in the adjoining wall that is close enough to the far end of the fixed panel. But if the fixed panel any of the middle 4, you'll need a floor receptacle.
Cheers, Wayne
Cheers, Wayne
Thank you so much for your clarification !!!
