pcsailor
- Minneapolis
Hi,
I may be missing something very basic but can someone explain something to me about NEC 2017_Annex D_Example D8_Motors_Page 800?
The example motor specs are given in the beginning (a) and (b) sections.
(a) is one 25-hp motor with a nameplate rating of 32 amps
(b) is two 30-hp motors with nameplate ratings of 38 amps (primary)
When you look through the example answers, in the 'motor overload protection' section, they're using the given 32 & 38 amps to calculate the answer.
With every other solution, they're using 34 and 40 amps, respectively, to determine the answer.
Why? Why have they up'ped the amps by 2 for the motor calculations?
Thank you,
Phil
Thank you,
Phil
