leboot
- Baltimore, MD United States
- Electrical Engineer
Hi all,
We're working on a high end residential apartment unit where the exterior walls are all sliding glass doors/panels. These sliding walls can either slide into a pocket or they can slide into the next room and the wall in the next room can slide into the first room (if that makes any sense). The size of these doors/panels is such that the distance between any wall mounted receptacles we have is greater than 12 feet.
NEC 210.52(A)(2)(2) - describes wall space as "the space occupied by fixed panels in exterior walls, excluding sliding panels."
I think we should provide floor receptacles so that no point measured along the exterior wall is more than 6 feet from a receptacle, but we're pretty sure the owner is going to come back and ask what is the minimum that is required.
So, my question is this: are all those sliding wall panels excluded from the definition of a wall space?
(We do have some columns here and there to mount receptacles, so they are some, just not a lot.)
Thanks for your input!
