I am building a new Publix store in Forsyth Co. Ga. The electrical inspector is enforcing this code change for all the 120 volt, 15 & 20 amp outlets in the Bakery/Deli area. I managed to convince him that it would not be a good idea to have all the refrigerated cases on these circuits to prevent nuisance tripping and possibly spoiling alot of food. The specs require these circuits to be twist-lock receptacles.
I have power poles in these areas and for non-refrigerated loads I have pulled one neutral per A,B,C phases. I am having to change the regular 120 volt straight blade receptacles to GFCI recepts to comply with this new code.
My question is, can a GFCI receptacle share a common neutral?
I have asked advice from numerous people and usually get a quick yes... however I seem to remember having alittle trouble in the past with this.
Is there an electrical reference source that will back me up... say a manufacturers data sheet or electrical textbook... or will I have to "wing it"...?
It is a change-order situation but time and conduit fill figure into wether I can accomplish this as a quick fix or a major problem. I do not wish to make a judgement call only to have them call back in a month to re-pull additional wire and eating the cost and looking incompetent.
