Nec 220.46 B track lighting
Jpflex
Electrician big leagues
Victorville
Electrician commercial and residential
I have seen local stores such as walmart add several track lighting to their exizting lighting years after opening.
If nec requires 150 VA per every 2 feet of track lighting or fraction thereof to be added to the [service or feeders load demand], then how are they doing this without having construction to increase service or feeder conductor ampacity size?
Are these business just adding these loads without knowledge of exceeding the original service or feeder demand load without electrical inspection
Or were these services or feeders build oversized to cover ampacity beyond the original calculated load?
Because the Article 220 load calculations are very conservative and often result in a service that is 50% larger than what is needed for the real world loads.
If there's a lot of linear feet they usually have some sort of current limiting device. Keep reading, you will see an exception. Many ways to reduce that load.
Everything’s led now won’t have a problem. That 150va is like a street light every 2 feet. They won't get there with track heads
If it’s all led
