Hi all, my question is related to NEC 220.82(B)(1) when doing dwelling unit load calculations. The section says that you take 3VA/ft^2 for general lighting and general-use receptacles. If I know the exact lighting load because I have the amount of lights and the wattage of those lights, and if I have the exact amount of general-use receptacles and took them at 180VA each, could I use those values instead of doing what NEC says? Thanks for the help!
