NEC 220.87 - Existing Loads from Utility Bill
curious101
Atlanta, GA, USA
Hi All,
Question regarding above listed: if I try to go by the utility bills to determine the maximum demand, but the monthly utility bills only list kWh as total usage for a certain number of billing days, do I convert this number for each month to get the peak demand kW data and then pick the highest value to multiply by 1.25 and add the new loads? If yes, is this kWh-to-kW conversion okay to use (basically divide the kWh by the total hours of the billing period)? https://www.inchcalculator.com/kwh-to-kw-calculator/
Please let me know if you have questions.
Thanks, and have a great day!
Hi All,
There is no way to get a maximum demand from kWH.
Hi All,
The error in your proposed calculation method is that it assumes the load is constant for the entire month. Since this assumption is erroneous, the calculation fails.
