Nec 225.32 - Ex. 1
AERICH
225.32 Says That A Sub Panel In A Seperate Building Must Have A Main Disconnect.
Ex. 1 States That If It Is Under Single Management And On The Same Property It Can Be Located Elseware On The Premises.
I Have A 400a Main Service With 2-200a Service Disconnects One Of Which Is Controlling A Distribution Section In The Same Panel. This Is Located Outside On The Garage.
We Fed 2-100a Sub Panels In The House (detached By Approx 50 Feet) Each With Approx. 20 Breakers In Them.
This Is A Private Residence. Does That Not Fall Under Exception 1 Of 225.32?
