hhsting
- Glen bunie, md, us
- Junior plan reviewer
Attached sketch has Top View and Side View. Have overhead service coming on roof weatherhead. The utility meter is located in basement inside building on the opposite side of building from weatherhead
Nec 2014 230.6(5) says conductors routed through an eave but not wall of a building.
Questions about attached sketch which one would be code compliant for conductors to be considered outside?:
1. Can conductors after service point be routed in eave from weatherhead to the opposite side of building then drop down to outside wall of building to the utility meter?
Or
2. Can the conductors from weatherhead routed go thru eave then 90 degree bent to underneath outside wall underneath but NOT in the eave to utilit meter point then drop down to side of bulilding to utility meter?
Or
3. Can after weatherhead service point the conductors can be routed on roof to the other side of building then drop down through eave and outside wall to the utililty meter?
Sent from my SM-G935U using Tapatalk
Or
Or
