example of a utilities req.
The Company will connect only one set of service conductors to each separate dwelling (single or
part of a multiple unit), apartment, farm, commercial or industrial establishment as one customer
through one meter or one unified set of meters. Therefore, customers will typically be served at
one voltage at either single-phase or three-phase, but not both. If the service location is occupied
by several customers, each customer may have one meter for each class of service rendered. All
customer installations shall conform to the NEC and local codes. Parallel runs of service cable
extending from Company-owned equipment to multi-position meter centers should be avoided and
require prior Company approval.
Upon request and if Company approved, a second service may be permitted based on the
exceptions listed in NEC Article 230.2. A permanent plaque or directory shall be installed at each
service drop or lateral, or at each service equipment location. It shall denote all other services on
or in that building or structure, and the area served by each.
