A builder is concerned that due to the new requirement in Va. , if there is reinforcing steel in the footing of a new building it must be used as the grounding electrode. The builder will need to wait for an inspector to check the electrode attached to the steel before concrete is placed for the footing. He is asking if a steel "stick-up" attached to the footing steel can be stubbed out above the concrtete slab from the footing steel and then attach the grounding electrode conductor to the steel stub-up.
I said no that the attachment of the G.E.C. to the footing steel in contact with the earth must be incased in the concrete within the footing.
Any thoughts?:
Any thoughts?:
