angel woodruff
- Saint Clair Shores MI
300.3 (C)(1)
Conductors of circuits rated 600 volts, nominal, or less, ac circuits, and dc circuits shall be permitted to occupy the same equipment wiring enclosure, cable, or raceway. All conductors shall have an insulation rating equal to at least the maximum circuit voltage applied to any conductor within the enclosure, cable, or raceway.
If my 480v and 24v are run in separate wire ducts within the enclosure does the 24v wiring need to maintain the same insulation rating as the 480v?
Can I get away with using a 600v rated wire for the 480v and a 300v rated wire for the 24v signals?
