erickench
- Brooklyn, NY
Okay, there is something about the above NEC section that does not make sense. How does a steel plate protect a cable that does not maintain a minimum 1-1/4" space from the edge of a framing member? I could understand if the cable was installed through a framing member. Then the steel plate would effectively protect it from nails. But how does it protect it if it's attached directly onto the framing member with absolutely no space but with less than 1-1/4" space from the nearest edge? What purpose does the steel plate serve and where would you install it? If the cable runs parallel at less than 1-1/4" from the framing member then the steel plate would have to be installed directly on the framing member between the framing member and the cable. I look at the pictures in Mike Holts books and the NEC handbook and it does'nt make any sense. The arrows indicate a space from a directly attached cable to the framing member but with 1-1/4" distance from the nearest edge.
