Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
NEC 310.15B2
Says to add a 60 degrees F to the ambient temperature when calculating and correcting conductor's ampacity, when it is in a cable or raceway with its bottom less than 3/4 from a roof or exposed to direct sunlight.
My 2023 handbook provides an example
A feeder runs less than 3/4 inches above a commercial building roof. This feeder supplies a calculated load of 175 A with an ambient temperature of 95 degrees ferenheight. None of the loads are continuos and the neutral is not considered current carrying (bundling effect)
QUESTION:
What is the size of THWN-2 ALUMINUM FEEDER rated at 90 degrees C is needed for this installation?
ANSWER:
New ambient temperature
95 degrees F + 60 degrees F = 155 deg f
Table 310.15B11
THWN-2 insulation rated 90 degrees c. Therefore, a 0.58 reduction to the conductor ampacity at 90 degrees c is required
175 ampere / 0.58 = 302 ampere aluminum conductor is to be selected from table 310.16
A 400 kcmil ALU conductor at 305 amperes at 90 degrees c is chosen
Then the book says according to 110.14 C, we must select a wire for 75 degree c when terminating onto equipment rated for 75 deg c
However, instead of including the 60 deg F adder to ambient temp as with the wire subject to 90 degree c limit, they do NOT include this adder to the 75 degree limit.
The book says the 400 kcmil aluminum THWN-2 can be used here for termination because at 75 deg F, the ampacity is 270 i amperes and is enough for the 175 i ampere load.
What does not make sense is that if NEC assumes that the condition of use by subjecting wire in direct sunlight or less than 3/4 above a roof causes elevated conductor temperature for a given ampere limit, then the ampacity is either lowered or a larger size wire is selected
Why then is nec not adding 60 degree adder to the wires ampacity at 75 degrees F and increasing the conductor size under the same condituons of direct sunlight ar distance from a roof?
If direct sunlight or distance above a roof less than 3/4 inch causes wire temperature to increase above its 90 degree C insulation temp limit at the 310.16 tables ampacity shown, it will surely do the same for the tables ampacity limit for the conductor at 75 degrees C
QUESTION:
ANSWER:
Table 310.15B11
