jajohnson977
- Franklin Park, IL, USA
I have an application where I have a 1500 amp circuit and on the load side of my distruibution block I have 32 legs (which all go to contactors for heating elements). I am not aware of any block that has that many load legs that is UL listed or recognized. What I have been doing is using (3) 3 pole distribution blocks that have 12 load side legs each. I use (1) 3 pole block (giving me 36 load side legs)for each phase assuming each line side has an equal amount of the same size conductor. However, someone was telling my I was voilating 310.4 stating that parallel conductors must be tied to each other at both ends. (1) Am I truly voilating NEC by doing this? (2) How else could I satisfy NEC and UL at the same time? (I've found a block from marathon that has 18 load side legs but has not been evaluated to accept two wires per leg, so that is out).
Any help would be appreciated.
Thanks,
Thanks,
