Does this chart refer to phase-phase voltages or phase-ground? I am trying to size the wire coming from a high voltage line to the primary side of a pole mounted transformer. Everyone I've talked to has told me to use a #6 solid copper with 5kV insulated sheathing. The voltage is 12470v/7200Y. To me it would seem you need a #2 minimum with a 15kV sheathing. What's the correct wire?
