NEC 334 says not permitted to use NM in wet or damp locations . If i use NM in PVC or car flex nonmetalic flex outside to a A/C condenser is that allowable under the NEC?
Nope. The inside of the raceway is considered a wet location and a conductor rated for wet locations is required.
That would be UF, not NM.... You could run NM suitable for underground burial inside of the flex. ...
It's done all the time,
Qualifier: The inside of a raceway is considered a wet location if the raceway is installed in a wet location.............![]()
