freddyt7
GM VP of the electrical division.
- stillwater, mn. usa
Hi - this part of the code states that you HDPE (PE roll pipe) can not be allowed to be above ground. In this case you need to transition from the HDPE pipe and then come up out of the ground with PVC or GRS.
Secondly, the code states that you can use an accepted method of joining or a mechanical device. In the case of wanting to use a bell ended PVC sweep mechanical seals don't work.
PVC pipe cement does not adhere to HDPE and is NOT accepted by the HDPE conduit manufacturers. They do allow when you go from pipe to pipe mechanical couplings, push on couplings or reverse threaded couplings and an adhesive called BonDuit. Which BonDuit adhesive, threaded and push on couplings are not mechanical. However. they are approved by the manufacturer.
If you were the AHJ and you saw the contractor had to meet the NEC code where they had to come out of the ground and had to transition between dissimilar conduit materials and they used an approved adhesive (letters from the conduit manufacturers) would you accept that as an approved method? The same goes for pipe to pipe underground using a push on non-mechanical coupling that was approved by the conduit manufacturer?
Finally, PVC pipe cement is an approved method for PVC pipe joining but does not have any UL mark. So, some of the above solutions also do not have UL marks.
Thank you for your time and consideration.
