NEC 400.8 (1) violations
anuta
New member
I am currently doing a research on the purpose of NEC 400.8 (1) statute - my question is: what was the primary purpose of creating this statute in terms of consumer safety? Is it primarily fire or trip and fall prevention? Thanks!
The problem with flexible cord it that the rubber used will deteriorate over time and become brittle and fall off. This can leave the conductors inside exposed to damage and possible failure of the insulation system which could lead to a fire.
For this reason flexible cord can not be used as a substitute for the use of other permanent wiring methods from Chapter 3.
Chris
Primarily fire. Remember this doesn't mean your mom can't use an extension cord. This means your electrician isn't supposed to use one in the wall to get you another outlet.
Also: STATUTE: Statutory Law: Law passed by a state. 400.8 is not a statute. It is typically "adopted by reference" to be enforced by statutory penalties.
I'm not sure my "Wayback" machine can go back that far!
I would guess that the section is not there because of anything specifcally 'wrong' with rubber cords. Rather, I would expect that limitation to be more one of 'definition,' one that goes back to the very beginning of the NEC.
That is, I would guess that it was recognized that there was a legitimate role for 'temporary' wiring, and that it would be silly to ask 'temporary' wiring to follow the same rules or use the same materials as 'permanent' wiring. From there, the code went on to describe various methods- and 400.8 simply classes cords as a 'temporary' method.
Beyond that, the NEC is a nest of grammatical gremlins, whose breeding is nurtured by the lack of an overall foundation and the complete ignoring of the declared scope. When the rulemakers don't follow their own rules - or lack such to start with - it's small wonder that the 'codemobile' weaves about like a drunk driver on an oiled glass plate.
