Nec 410.30(b)(2)
erickench
Brooklyn, NY
I read the above NEC section and I'm trying to grasp the description. The NEC section reads:
Where raceway risers or cable is not installed within the pole, a threaded fitting or nipple shall be brazed, welded, or attached to the pole opposite the handhole for the supply connection.
I've attached a diagram for all to see. Can someone tell me if the diagram corresponds with what's stated in the code?
Eric,
Your picture indicates the wiring entering from the bottom. The code section is talking about a raceway exterior to the light pole. The welded fitting would be on the side of the pole 180 degrees from the wiring access hand hole.
Eric
They mean something like this:
Now my question. Would this pass based on the wording of 410.30(b)(2)?
No it would'nt. I don't know what they mean when they say opposite the handhole. I'm sure your picture is right. It just has to be worded properly.
I see no problem with the wording. Opposite the hand hole is pretty straight forward.
This first picture shows a nipple entering opposite the hand hole. (There may still be violations here but it does illustrate 'opposite the hand hole'.)
The picture below shows a nipple entering that is not opposite the hand hole and clearly in violation of 410.30(B)(2)
I was under the impression that a handhole is an underground enclosure and not an opening in the side of a pole. At least that's how the NEC defines it.
Okay Mike Holt has it worded as "Handhole opening" in his book. But is it really a handhole? i.e underground enclosure.
The word handhole seems to be used in all the trades and basically means:
A shallow access hole large enough for a hand to be inserted for maintenance and repair of machinery or equipment.
It's just that the NEC defines "Handhole Enclosure" as being underground.
