Per 410.66(B):
Thermal insulation shall not be installed above a recessed luminaire or within 3" of the luminaire's enclosure....
Can I place a drywall box around the fixture and lay insulation on top of the box if I keep enough clearance? How much clearance would be required?
If you take this phrase literally, you couldn't install insulation on the 13th floor if it is above a fixture on the 1st floor!!
Steve
Steve
