megloff11x
I believe that NEC should provide a dedicated section for Servo Motor Systems under the Motors section. These systems are getting very sophisticated. They have added many very robust safety features to protect the motor and the machinery. They are used increasingly in factories for moving material and in machines, particularly robotics. The existing code doesn't "fit" well because the motor sizes and Voltages vary significantly from the standard sizes for induction & synchronous motors, VFD, and contactors. They are often mounted on moving parts, and thicker cable, even if properly ated for continuous flexing and twisting, will fail sooner than thinner cable. I've never seen one melt its wires. Inrush is also limited in more recent designs.
Is there a way to persuade the NFPA to get together with the foreign and domestic manufacturers of these systems and develop more specific standards?
It would be very nice from both the NEC and NFPA 79 to be able to use their firmware/software controlled limit and stop features in lieu of additional hardware. Several are working on getting their features listed for this purpose. I do believe that their built in functionality is faster and safer.
Matt
Matt
