bbrown0921
New member
- Ft Lauderdale, Fl.
Code:
440.14 allows the disconnect for an air handler to be on or within the air handler. Does this mean the disconnect can be behind the front access panel and only visible when the panel is removed. We find air handlers constructed from the factory both ways. If the disconnect is outside the unit I don't have to install a separate disconnect, but if the disconnect is inside the unit do I have to install a separate disconnect or does the inside disconnect meet NEC??
