Jim Hughes
New member
I have a question on Article 460.1 and 460.2 in regards to power factor correction capacitors and the dielectric oil used in these capacitors.
We are a OEM manufacture of power factor correction equipment and I have a client spec calling out the following pertaining to medium voltage capacitors and dielectric fluid used in capacitors.
Client spec is as follows.
?Installation shall comply with the latest edition of the National Electric Code Article 460 and shall meet the NEC indoor installation requirement for having less than three gallons of dielectric fluid.?
Our equipment would use six capacitors each containing 3.3 gallons of fluid. The capacitors would be assembled with other equipment inside a metal enclosed enclosure for indoor service. Access is guarded by lock and key.
In reading Article 460.1 Scope, NEC states the following ?Surge capacitors or capacitors included as a component part of other apparatus and conforming with the requirements of such apparatus are excluded from these requirements.?
Since we are using the capacitors as components of a system and build to standards for this type of equipment, I read the NEC 460.1 Scope as we are excluded from these requirements. Can anyone shed some light on this and let me know if I?m correct in what I read from NEC.
Thanks in advance for your help.
Regards
Jim Hughes
Power Survey
Regards
Jim Hughes
Power Survey
