erickench
- Brooklyn, NY
The above NEC section seem's to be a little confusing. NEC 500.5(C)(1)(2) states the following condition for a Class II Div. I location:
Where mechanical failure or abnormal operation of machinery or equipment might cause such explosive or ignitable mixtures to be produced, and might also provide a source of ignition through simultaneous failure of electrical equipment, through operation of protection devices, or from other causes,
And NEC 500.5(C)(2)(3) states the following condition for a Class II Div. II location:
In which combustible dust accumulations on, in, or in the vicinity of the electrical equipment could be sufficient to interfere with the safe dissipation of heat from electrical equipment, or could be ignitable by abnormal operation or failure of electrical equipment.
I do not see the difference between these two conditions. In both cases the explosion would be caused by failure of electrical equipment. The first case mentions protection devices followed by the phrase "or other causes,". What do you guys make of this?
