erickench
- Brooklyn, NY
The new change in the 2008 NEC includes a statement in the above section that I find puzzling:
Each means(disconnecting) shall be readily accessible and within sight of it's equipment and shall be located at least 5 ft. horizontally from the inside walls of the pool, spa, or hot tub unless separated from the open water by a permanently installed barrier that provides a 5 ft. reach path or greater.
How does a barrier provide a 5 ft. reach path? Let's assume that the disconnect is 3 ft. from the water. What is the barrier going to do? I mean I could understand it providing a blocking obstruction but what is this 5 ft. reach path,
