erickench
- Brooklyn, NY
I'm looking at NEC 680.22(A)(1) and 680.22(B). These two rules give differing conditions for providing GFCI protection for receptacles or outlets supplying pool pump motors. In the first case the condition is that the receptacle is located between 6-10 feet from the inside walls of the pool. In the second case the condition would seem to indicate that a branch circuit with short-circuit and ground-fault protection is used to supply a pool pump motor. However, in this second case the GFCI protection would be provided regardless of distance and in all cases where there is short-circuit and ground-fault protection. If it weren't for the condition of their being short-circuit and ground-fault protection then there would be a conflict between the two rules. Am I correct in assuming this?:blink:
