NEC 680.27(C)
wyboy
Section 680.27(C) on pool deck heating applies to electrically operated comfort heating units. Part (3) of that article says ?Radiant Heating Cables Not Permitted,? and states, ?Radiant heating
cables embedded in or below the deck shall not be permitted.? My question is a PVC drain pipe in the 20? restricted area with a heat cable inside to prevent freezing. (This is for an outside
hot tub.) Since the heat cable is not a comfort heating unit, is it allowed?
