NEC 690.12 and 690.13.
wyboy
I have questions regarding NEC 690.12 and 690.13.
An installation consisting of a house and barn has an array on both structures. The photovoltaic output circuits from the array on the barn feeds through a DC disconnect on the barn then in underground conduit to the inverter in the house. The photovoltaic output circuits from the array on the house feeds to the inverter in the house. (The inverter in the house is not located immediately upon entry.) Rapid shutdown is accomplished by optimizers on the panels and a disconnect by the service.
Question 1: NEC 690.12 requires PVC circuits installed on buildings shall have a method for rapid shutdown. It has no requirements for location. Does the disconnect on the house meet rapid shutdown requirements for the barn?
Question 2: NEC 690.12 requires a disconnect for DC conductors feeding a different building or structure. The rapid shutdown disconnect would certainly kill power from the photovoltaic output circuits from the barn. Does rapid shutdown disconnect meet the requirements of NEC 690.12 or is a separate DC disconnect required where the photovoltaic output circuits from the barn enter the house? If not does the disconnect on the barn meet the requirements?
