mastadon13
Trying to clarify the application of NEC 700.9, any help is appreciated.
I am working on the electrical design to do a wholesale replacement of packaged air handling units on the roof of a facility (~25 of them). Per owner request and to match the existing installation, the supply fan of each unit is to be on generator backup power, but the rest of the unit (compressor, combustion, etc.) is to be on utility power. The existing installation has two seperate power feeds (one normal, one emergency) to seperate fused disconnects mounted on the unit, but once inside the unit I don't think there is any real seperation of the emergency wiring and the normal utility power. Is this in violation of NEC 700.9? Or is it OK because it is inside the unit?
I am asking because I was planning on essentially re-using the existing conduit path and having the same two disconnect system, but I am concerned about meeting code within the unit.
