NEC 700.(D) Use - Transfer equipment shall supply only emergency loads.
I am working in a building with a 150kW, 280V/3PH outdoor backup diesel generator. The generator feeds one ATS and one downstream panel (EM). Panel EM has both emergency loads (egress lights, exit signs and fire alarm panel) and other non-emergency loads.
To comply with above NEC rule without adding another ATS/panel to separate emergency loads from non-emergency loads, I am thinking to install an inverter, then disconnecting all emergency circuits from panel EM and re-feed them from the inverter. This meant the emergency loads are now backuped by another source not generator as allowed by NEC 700. Questions:
1) Can the inverter still be fed out of panel EM or it has to be fed from another non-generator panel?
2) If the inverter can be fed out of panel EM, technically, the emergency loads now have two backup power sources (inverter and generator) is but still on same ATS as other loads, will this comply with NEC 700(D) above?
3) In either scenario, the generator is no longer classified as generator, correct?
