chuck@apsinc.biz
- Colorado
I am working on a project that has an architectural cove. In the base of this cove I want to put a mini-down light, this down-light is Low-Voltage 35W MR11. I purchased a Class 2, 60VA fused electronic transformer.
The transformer looks like a car key fob and has 4-wires coming off of it. (1)Black, and (1)White for the 120V AC Supply side Feed and (2) red for the 12VAC Load Side Feed. There are no provisions to be connected to a junction box ect., it literilly is a small black box with 4 wires coming out of it.
NEC 725.51 Says conductors and equipment on the supply side of the power source shall be installed in accordance with the appropriate requirements of Chapters 1 through 4.......
I have a 120V, 20A MC Whip coming to the fixture location. I am struggling with how do I interface the MC whip and the line side power of the transformer.
Do I set a J-box, put the transformer in the J-box, and run the 12V wires through a grommet out of the J-Box then continue with the LV wiring to the Mini-Can?
Do I set a J-box, leave the transformer out of the J-Box and run the 120v leads through a grommet into J-Box and make the 120V connection.
Do I terminate the MC cable into a connector and make the 120V connection to the transformer in the open?
Any input would be greatly appreciated.
