Hi,
I am doing research on the use of aluminum branch circuit wiring.
The NEC permits the use of Al wiring #12 and larger. I found a map of the states which have adopted the NEC.
My questions are:
1. Can those states that adopt the NEC also have a state/local rule which does not permit Al #10 and #12?
2. Does anyone know a way to find out which jurisdictions have banned the use of #10 and #12 branch circuit wiring?
3. How I can found if aluminum branch circuit wiring has been commonly installed since the 1970s publicity alerting the public of the dangers associated with aluminum wiring.
Thank you.
My questions are:
Thank you.
