Cathodic Civil Guy
- Houston Texas
- Engineer
Greetings all. Long time lurker and finally joined up. I see there are a several cathodic protection (CP) posts, figured maybe I can start to give back to the community as related to CP. Y’all are an amazing wealth of knowledge and a big thank you is due for the guidance shared here.
Here is my question - Does NEC apply to DC wiring downstream of a rectifier?
When I started in the CP business, I was told by the old timers that NEC did not apply to these cables. I’m to the point now where I need to back up this theory with a real explanation / code interpretation.
For a typical example, the DC negative cable from the rectifier is bonded to a steel bulkhead and the DC positive cable runs to a deep well anode bed.
These systems typically run below 60 volts on the DC side.
I also speculate that NEC does not apply for other reasons:
- The CP world uses HMWPE cable almost exclusively and I can find no mention of this insulation type in Article 310.4 .(specifically Table 310.4(1)
- All I can find in NEC related to “Cathodic Protection” is isolation of objectionable ground currents.
- Section 300.1(B) ‘could’ be interpreted that the downstream DC cables are 'integral' to the cathodic protection equipment.
