In this paragraph it states "the grounding electrode conductor shall be permitted to be connected to the equipment grounding terminal bar, or bus to which the main bonding jumper is connected." Is this correct?
It is my understanding that the ground electrode conductor should be connected to the grounded conductor terminal bar or bus and that the grounded terminal bar or bus is bonded with the equipment terminal bar or bus.
