The classical conductor selection based on the terminal equipment temperature rating:
If a 90 deg C rated insulated conductor is terminated at a 75 deg C equipment in a 30 dec C ambient and this same conductor is routed through a 40 deg C ambient location, can this conductor size be selected based on the 90 deg C amapacity without exceeding the 75 deg C temperature in the 30 deg C ambient location?
