I am feeding an adjacent building which has an existing 208 volt service from a newly constructed switchgear next door which has a 480 volt service. I am disconnecting the utility service (already met with utility) and providing a 480v/120/208 volt transformer and refeeding the existing service. I am not planning to use a 480 volt disconnect prior to the transformer inside the building since I have overcurrent protection prior to the transformer from the switchgear next door. The 208 volt disconnect is approx. 10 feet from the transformer and 20 ft from where the conductors enter the building? Does this violate 225.32 "Install at a readily accessible location nearest the point of entrance of the conductors"
