NEC Articles referring to splice or tap of two different wire sizes?
mtsolarken
New member
United States
I found this definition of a splice in the forums here by a senior member, "Splice: A connection of two wires of equal size, such that one wire ends and the other wire begins at the connection point. The wires can be of different sizes, so long as the smaller wire is protected at its ampacity by the overcurrent device that is upstream of the first wire. "
I'm not entirely clear if this is a splice or a tap.
I removed an exterior light fixture that was fed with 14-2 NM and installed a box there. I have spliced the 14-2 into 12-2 to feed 4 new recessed lights in the waterproofed outdoor ceiling area that I have built. The branch circuit breaker is a 15A and I don't intend on changing it.
The inspector has told me that we can't change wire sizes in this circuit. After thinking about it and calling a friend with a C10 license that agreed that it can be done. I have been looking for an NEC article that states so. Two hours into my search I decided to post the question here.
You can changes wire sizes in a circuit as long as the circuit is protected for the smallest size wire
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
