What does the NEC say about grounding a box that has wire pulled through it? (no splices, insulated conductors only)
The installtion: A 480v/30a 3phase circuit with an insulated ground wire from a power panel, underground thru 1 inch PVC conduit , thru a metal 'pull box', to another metal box and finally at the load.
Do all metal 'pull boxes' containing non-spliced wire require grounding / bonding ?
Thanks - Mike Detroit,Mi
