Installing a new 208/120V, 100A, Square D MLO panelboard fed from an existing distribution panel for a job. The project manager rejected the panel I submitted because I did not submit a lug cover for the MLO lugs, therefore not meeting the new NEC Code Requirement (he did not reference the code in his response). Is there a code that requires a lug cover at the connection point of an MLO panel?
He also left a comment that an Arch Flash Label is required. This is the first new panel I've had to provide, in the past I've been able to use existing panels that already have arch flash labels. Does the manufacturer of the panelboard (Square D) typically provide an Arch Flash Label or do I need provide one?
Thanks
Thanks
