NFPA 70E is not written to be used as a code. This is no different than many of the other NFPA standards.NFPA 70E requires a hazard analysis which leads to an arc flash study, but no jurisdictions that I'm aware of has adopted NFPA70E as a code. 70E typically get invoked when someone gets hurt and OSHA asks why someone was working energized without a hazard analysis.
... unfortunately (for me anyway since that's my line of work) the wording says "field or factory applied" which implies it can just be generic. The only place I can find that actual values are needed is this requirement for fault current availablilty:From NEC 2023 via NFPA Link there are 11 references to arc flash.
110.16(B)
240.67 & 240.87
... and on and on.
So there's no actual requirement for a Study per se, but labels are required for certain pieces of equipment, and arc flash is addressed for fuses and breakers in the 240.67 and 87 sections.
But the NEC does not require any Arc Flash Incident Energy value nor a PPE Category, so its labeling requirements do not meet NFPA 70E.... unfortunately the wording says "field or factory applied" which implies it can just be generic. The only place I can find that actual values are needed is this requirement for fault current availablilty:
110.24 Available Fault Current.
(A) Field Marking.
Service equipment at other than dwelling units shall be legibly marked in the field with the available fault current. The field marking(s) shall include the date the fault-current calculation was performed and be of sufficient durability to withstand the environment involved. The calculation shall be documented and made available to those authorized to design, install, inspect, maintain, or operate the system.
