JJWalecka
- New England
What is the job description of an NEC Consultant?
I would guess that anyone can call themselves a consultant. The more stuff you can put after your name on a resume the better your chances are of convincing someone that you are a qualified one.
What would be the prerequisites? Is there a certification that you are aware of?
I would consider Mike Holt an NEC consultant
If you check, wouldn't that be with their consent... because, legally, you cannot without their consent.Legally, you may want to check with NFPA if you can use their registered trademark name without their consent.
Yes, but then it would be with their permission, to the extent permitted, and otherwise without their consent... the latter constituting infringement.No Sir, checking with NFPA about the restriction or liberty of the use would establish the boundary limits. The answer could be either the standard limitations of the use of registered trademarks, or special provisions on the use. As an example, according to the basic law, anytime when NEC is mentioned in writing it should appear as so: NEC(R).
Has anyone read inside the back cover of a recent NEC?
It states that the document is made available for both public and private uses, but does not waive any copyright protection by doing so.
I would read that to mean that a person does not need the NFPA's permission to be a consultant for the NEC, but would need their permission to actually copy it or parts of it.
So long as all the copy written material is copacetic, I think anyone could call their self a consultant and not be an issue with the NEC.
The states may have an issue, though. A person may need some sort of a license to do any consultation related to certain professions.[/QU
The issue is not the question of quoting material from NEC(R) publications, but the use of the NEC(R) title itself, which is a registered trademark. (Incidentally copying parts is allowed under general copyright laws as long as the source is identified. Replicating the entire document or even whole sections of it is not permitted.)
OK, so at least part of the question would be the use of NEC in, say, an ad. For instance, an ad in a phone book that says, Joe Soandso, NEC Consultant, correct?
That would be prudent concern, as such a title would imply some formal connection with the NEC.
I wonder what sort of arrangement the NJATC has with the NEC? Or the many other books that are part of the apprenticeship program? 'NEC' appears dozens or more times in the NJATC written books. Also, code and chapter numbers, direct quotes from the NEC, etc. are ubiquitious.
I don't know anything about the legal issues of using the term NEC in one's advertising - so I have nothing to say about that.
However, having dealt extensivly with two nationally recoganized code expert consultants, I can say for certanty: a clear knowledge of exactly what the code is trying to accomplish - is not a requirement.
The most important thing is to publish. The only important thing is to publish. The more one publishes the more one can charge.
No, niether of the two were MH.
ice
